It is currently Mon Aug 11, 2025 8:12 am
PostPosted: Fri Sep 02, 2016 10:42 pm
What final film thickness should a properly applied nitro coat be?
Thanks...
PostPosted: Fri Sep 02, 2016 11:34 pm
I don't know if it's proper or not but I spray an average of about .0007-.0008/coat. I measure after I've sprayed several coats that day then let it dry for a day or so. I use a micrometer at the sound hole and try to measure it in the same spot each time.
PostPosted: Fri Sep 02, 2016 11:36 pm
Last Name: Beaver
City: Lake Forest
Far from an expert, and i hardly know right from wrong, but I usually have 5-6 mills, before sanding
Joe Beaver
Maker of Sawdust
PostPosted: Sat Sep 03, 2016 12:31 am
I misread the initial post, sorry, for final thickness I end up in the same range as Joe about .oo6 prior to final sanding and buffing. I end up at about .004 when all sanded and buffed.
PostPosted: Sat Sep 03, 2016 3:30 am
Thank you.
Would love more verification of those numbers, which are in line with what I think I should be able to expect from a professional finisher.
PostPosted: Sat Sep 03, 2016 6:46 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
About .004" after sanding and buffing for the top. I used a wet coat mil gauge when I started practicing lacquer finishing to be able to see what a good, wet coat looked like, and to try to gain some consistency on per-coat dry thickness. Some day I know I will get there!
- Beth Brower
PostPosted: Sat Sep 03, 2016 7:58 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I target my nitro finishes to 5 mils total after buffing. I loose about 2 in level and buff so an overall dry film of 7 mils.
Brian
PostPosted: Sat Sep 03, 2016 8:01 am
I use 3M thin blue masking tape to mask the bridge & fretboard extension areas on the top prior to finishing. After leveling the last coat of lacquer, I end up with the tape level with the surface of the top. Subsequent measuring of the lacquered tape after removal will indicate the thickness of the top finish. My nitro finishes measure about .004" -.005" after leveling and buffing.
Mike Franks
http://www.mjfranksguitars.com
http://www.facebook.com/mjfranksguitars
PostPosted: Sat Sep 03, 2016 12:43 pm
Thanks folks!
Users browsing this forum: Gary Davis and 43 guests
